Time Before: 0.00163 seconds
Time After: 0.00208 seconds
Time Before: 0.00215 seconds
Time After: 0.00250 seconds
Time Before: 0.00267 seconds
Time After: 0.00277 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00341 seconds
Time After: 0.00608 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00282 seconds
Time After: 0.00967 seconds
Time Taken: 0.00684 seconds
Time Before: 0.01162 seconds
Time After: 0.01200 seconds
Time Before: 0.01441 seconds
Time After: 0.01557 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01100 seconds
Time After: 0.01574 seconds
Time Taken: 0.00474 seconds
Time Before: 0.02167 seconds
Time After: 0.02228 seconds
Time Taken: 0.00061 seconds
Time Before: 0.02505 seconds
Time After: 0.02684 seconds
Time Taken: 0.00179 seconds
End call of global.php: 0.029433012008667
Time Before: 0.03120 seconds
Time After: 0.03143 seconds
Time Before: 0.03434 seconds
Time After: 0.03586 seconds
Time Taken: 0.00152 seconds
SET lastactivity = 1777009361, location = '/forums/private.php?do=newpm&explain=1&u=113950', badlocation = 1
WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.04922 seconds
Time After: 0.04966 seconds
Page generated in 0.048297882080078 seconds with 9 queries, spending 0.0092458724975586 doing MySQL queries and 0.03905200958252 doing PHP things.
