Time Before: 0.00187 seconds
Time After: 0.00247 seconds
Time Taken: 0.00060 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.00255 seconds
Time After: 0.00322 seconds
Time Taken: 0.00067 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.00347 seconds
Time After: 0.00359 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.00431 seconds
Time After: 0.00731 seconds
Time Taken: 0.00300 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.00365 seconds
Time After: 0.01073 seconds
Time Taken: 0.00709 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.195 KB
Time Before: 0.01257 seconds
Time After: 0.01303 seconds
Memory Before: 2,758.008 KB
Memory After: 2,758.625 KB
Time Before: 0.01444 seconds
Time After: 0.01566 seconds
Memory Before: 2,770.180 KB
Memory After: 2,770.039 KB
Time Before: 0.01192 seconds
Time After: 0.01586 seconds
Time Taken: 0.00394 seconds
Memory Before: 2,750.156 KB
Memory After: 2,883.398 KB
Memory Used: 133.242 KB
Time Before: 0.02075 seconds
Time After: 0.02089 seconds
Memory Before: 3,436.508 KB
Memory After: 3,437.023 KB
Time Before: 0.02326 seconds
Time After: 0.02447 seconds
Memory Before: 3,524.281 KB
Memory After: 3,524.875 KB
End call of global.php: 0.026124000549316
Time Before: 0.02719 seconds
Time After: 0.02734 seconds
Memory Before: 4,162.195 KB
Memory After: 4,162.625 KB
Time Before: 0.02938 seconds
Time After: 0.03096 seconds
Time Taken: 0.00158 seconds
Memory Before: 4,443.734 KB
Memory After: 4,445.422 KB
SET lastactivity = 1785297771, location = '/forums/private.php?do=newpm&explain=1&u=113962'
Time Before: 0.04600 seconds
Time After: 0.04635 seconds
Memory Before: 4,922.039 KB
Memory After: 4,922.266 KB
Page generated in 0.045118808746338 seconds with 9 queries, spending 0.0089046955108643 doing MySQL queries and 0.036214113235474 doing PHP things.
