Time Before: 0.00164 seconds
Time After: 0.00244 seconds
Time Taken: 0.00080 seconds
Time Before: 0.00254 seconds
Time After: 0.00300 seconds
Time Before: 0.00320 seconds
Time After: 0.00331 seconds
Time Before: 0.00416 seconds
Time After: 0.00649 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00336 seconds
Time After: 0.01109 seconds
Time Taken: 0.00773 seconds
Time Before: 0.01319 seconds
Time After: 0.01362 seconds
Time Before: 0.01645 seconds
Time After: 0.01771 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01248 seconds
Time After: 0.01796 seconds
Time Taken: 0.00548 seconds
Memory After: 2,261.703 KB
Time Before: 0.02466 seconds
Time After: 0.02480 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02705 seconds
Time After: 0.02871 seconds
Time Taken: 0.00166 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.03141188621521
Time Before: 0.03306 seconds
Time After: 0.03335 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03634 seconds
Time After: 0.03778 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=113989'
Time Before: 0.05133 seconds
Time After: 0.05162 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.050437927246094 seconds with 9 queries, spending 0.0084178447723389 doing MySQL queries and 0.042020082473755 doing PHP things.
