Time Before: 0.00149 seconds
Time After: 0.00207 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00213 seconds
Time After: 0.00277 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00307 seconds
Time After: 0.00325 seconds
Time Before: 0.00392 seconds
Time After: 0.00652 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00330 seconds
Time After: 0.00989 seconds
Time Taken: 0.00660 seconds
Time Before: 0.01184 seconds
Time After: 0.01221 seconds
Time Before: 0.01474 seconds
Time After: 0.01595 seconds
Time Before: 0.01125 seconds
Time After: 0.01613 seconds
Time Taken: 0.00487 seconds
Time Before: 0.02110 seconds
Time After: 0.02120 seconds
Time Before: 0.02313 seconds
Time After: 0.02446 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.026092052459717
Time Before: 0.02719 seconds
Time After: 0.02731 seconds
Time Before: 0.02930 seconds
Time After: 0.03073 seconds
SET lastactivity = 1784745118, location = '/forums/private.php?do=newpm&explain=1&u=114040', badlocation = 1
Time Before: 0.04472 seconds
Time After: 0.04501 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
Page generated in 0.043725967407227 seconds with 9 queries, spending 0.0082707405090332 doing MySQL queries and 0.035455226898193 doing PHP things.
