Time Before: 0.01951 seconds
Time After: 0.02409 seconds
Time Taken: 0.00458 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02418 seconds
Time After: 0.02458 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02483 seconds
Time After: 0.02497 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02584 seconds
Time After: 0.02840 seconds
Time Taken: 0.00256 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02505 seconds
Time After: 0.03272 seconds
Time Taken: 0.00767 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03989 seconds
Time After: 0.04024 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04279 seconds
Time After: 0.04400 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.03902 seconds
Time After: 0.04429 seconds
Time Taken: 0.00528 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.08164 seconds
Time After: 0.08179 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.12079 seconds
Time After: 0.12203 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.15192 seconds
Time After: 0.15211 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.15578 seconds
Time After: 0.15725 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=114047', badlocation = 1 WHERE sessionhash = 'c9ecef9835dff112a7666634a7a1b42a'
Time Before: 0.18411 seconds
Time After: 0.18448 seconds
Memory Before: 5,997.836 KB
Memory After: 5,998.055 KB
