Time Before: 0.00844 seconds
Time After: 0.01434 seconds
Time Taken: 0.00590 seconds
Time Before: 0.01445 seconds
Time After: 0.01492 seconds
Time Before: 0.01523 seconds
Time After: 0.01539 seconds
Time Before: 0.01617 seconds
Time After: 0.01883 seconds
Time Taken: 0.00266 seconds
Time Before: 0.01545 seconds
Time After: 0.02295 seconds
Time Taken: 0.00750 seconds
Time Before: 0.03017 seconds
Time After: 0.03066 seconds
Time Before: 0.03333 seconds
Time After: 0.03457 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02947 seconds
Time After: 0.03478 seconds
Time Taken: 0.00530 seconds
Memory After: 2,261.820 KB
Time Before: 0.04845 seconds
Time After: 0.04865 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.05998 seconds
Time After: 0.06122 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.063284158706665
Time Before: 0.06909 seconds
Time After: 0.06926 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.07175 seconds
Time After: 0.07320 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789034536, location = '/forums/private.php?do=newpm&explain=1&u=114125'
Time Before: 0.09008 seconds
Time After: 0.09034 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.088709115982056 seconds with 9 queries, spending 0.0083377361297607 doing MySQL queries and 0.080371379852295 doing PHP things.
