Time Before: 0.00192 seconds
Time After: 0.00255 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00265 seconds
Time After: 0.00339 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00368 seconds
Time After: 0.00382 seconds
Time Before: 0.00447 seconds
Time After: 0.00702 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00387 seconds
Time After: 0.01038 seconds
Time Taken: 0.00652 seconds
Time Before: 0.01210 seconds
Time After: 0.01256 seconds
Time Before: 0.01511 seconds
Time After: 0.01641 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01155 seconds
Time After: 0.01659 seconds
Time Taken: 0.00504 seconds
Memory After: 2,261.820 KB
Time Before: 0.02197 seconds
Time After: 0.02211 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02398 seconds
Time After: 0.02521 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.026808023452759
Time Before: 0.02928 seconds
Time After: 0.02943 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03132 seconds
Time After: 0.03285 seconds
Time Taken: 0.00153 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789109705, location = '/forums/private.php?do=newpm&explain=1&u=114129'
Time Before: 0.04507 seconds
Time After: 0.04533 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.044188022613525 seconds with 9 queries, spending 0.0085098743438721 doing MySQL queries and 0.035678148269653 doing PHP things.
