Time Before: 0.00145 seconds
Time After: 0.00275 seconds
Time Before: 0.00283 seconds
Time After: 0.00405 seconds
Time Before: 0.00427 seconds
Time After: 0.00440 seconds
Time Before: 0.00504 seconds
Time After: 0.00709 seconds
Time Taken: 0.00205 seconds
Time Before: 0.00445 seconds
Time After: 0.01054 seconds
Time Taken: 0.00609 seconds
Time Before: 0.01228 seconds
Time After: 0.01264 seconds
Time Before: 0.01499 seconds
Time After: 0.01621 seconds
Time Before: 0.01170 seconds
Time After: 0.01647 seconds
Time Taken: 0.00477 seconds
Time Before: 0.02362 seconds
Time After: 0.02378 seconds
Time Before: 0.02605 seconds
Time After: 0.02772 seconds
Time Taken: 0.00167 seconds
Time Before: 0.03145 seconds
Time After: 0.03162 seconds
Time Before: 0.03363 seconds
Time After: 0.03506 seconds
UPDATE session SET lastactivity = 1789112644, location = '/forums/private.php?do=newpm&explain=1&u=114174', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05145 seconds
Time After: 0.05173 seconds
