Time Before: 0.00225 seconds
Time After: 0.00343 seconds
Time Taken: 0.00118 seconds
Time Before: 0.00353 seconds
Time After: 0.00404 seconds
Time Before: 0.00429 seconds
Time After: 0.00444 seconds
Time Before: 0.00532 seconds
Time After: 0.00760 seconds
Time Taken: 0.00228 seconds
Time Before: 0.00452 seconds
Time After: 0.01300 seconds
Time Taken: 0.00848 seconds
Time Before: 0.01577 seconds
Time After: 0.01615 seconds
Time Before: 0.01880 seconds
Time After: 0.02000 seconds
Time Before: 0.01497 seconds
Time After: 0.02025 seconds
Time Taken: 0.00528 seconds
Time Before: 0.03469 seconds
Time After: 0.03485 seconds
Time Before: 0.06277 seconds
Time After: 0.06398 seconds
End call of global.php: 0.066678047180176
Time Before: 0.06813 seconds
Time After: 0.06827 seconds
Time Before: 0.07032 seconds
Time After: 0.07182 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1772808211, location = '/forums/private.php?do=newpm&explain=1&u=114175', badlocation = 1
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.08523 seconds
Time After: 0.08549 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.084270000457764 seconds with 9 queries, spending 0.0077869892120361 doing MySQL queries and 0.076483011245728 doing PHP things.
