Time Before: 0.00210 seconds
Time After: 0.00278 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00286 seconds
Time After: 0.00328 seconds
Time Before: 0.00353 seconds
Time After: 0.00368 seconds
Time Before: 0.00461 seconds
Time After: 0.00721 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00376 seconds
Time After: 0.01258 seconds
Time Taken: 0.00882 seconds
Time Before: 0.01471 seconds
Time After: 0.01511 seconds
Time Before: 0.01828 seconds
Time After: 0.01951 seconds
Time Before: 0.01408 seconds
Time After: 0.01971 seconds
Time Taken: 0.00563 seconds
Time Before: 0.02657 seconds
Time After: 0.02672 seconds
Time Before: 0.02889 seconds
Time After: 0.03013 seconds
Time Before: 0.03474 seconds
Time After: 0.03496 seconds
Time Before: 0.03732 seconds
Time After: 0.03877 seconds
UPDATE session SET lastactivity = 1784722621, location = '/forums/private.php?do=newpm&explain=1&u=11422' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.05798 seconds
Time After: 0.05826 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
