Time Before: 0.00134 seconds
Time After: 0.00188 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00195 seconds
Time After: 0.00242 seconds
Time Before: 0.00271 seconds
Time After: 0.00285 seconds
Time Before: 0.00387 seconds
Time After: 0.00683 seconds
Time Taken: 0.00296 seconds
Time Before: 0.00293 seconds
Time After: 0.01222 seconds
Time Taken: 0.00929 seconds
Time Before: 0.01439 seconds
Time After: 0.01474 seconds
Time Before: 0.01723 seconds
Time After: 0.01860 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01371 seconds
Time After: 0.01878 seconds
Time Taken: 0.00507 seconds
Time Before: 0.02382 seconds
Time After: 0.02397 seconds
Time Before: 0.02564 seconds
Time After: 0.02688 seconds
End call of global.php: 0.028984069824219
Time Before: 0.03014 seconds
Time After: 0.03044 seconds
Time Before: 0.03248 seconds
Time After: 0.03404 seconds
Time Taken: 0.00155 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=114242'
Time Before: 0.04652 seconds
Time After: 0.04678 seconds
Page generated in 0.045626878738403 seconds with 9 queries, spending 0.0087897777557373 doing MySQL queries and 0.036837100982666 doing PHP things.
