Time Before: 0.00297 seconds
Time After: 0.00388 seconds
Time Taken: 0.00091 seconds
Memory Before: 532.883 KB
Memory After: 558.000 KB
Time Before: 0.00395 seconds
Time After: 0.00435 seconds
Memory Before: 557.938 KB
Memory After: 558.945 KB
Time Before: 0.00457 seconds
Time After: 0.00469 seconds
Memory Before: 559.500 KB
Memory After: 560.023 KB
Time Before: 0.00540 seconds
Time After: 0.00863 seconds
Time Taken: 0.00323 seconds
Memory Before: 562.625 KB
Memory After: 563.547 KB
Time Before: 0.00474 seconds
Time After: 0.01200 seconds
Time Taken: 0.00727 seconds
Memory Before: 559.273 KB
Memory After: 1,640.320 KB
Memory Used: 1,081.047 KB
Time Before: 0.01448 seconds
Time After: 0.01489 seconds
Memory Before: 2,135.250 KB
Memory After: 2,135.867 KB
Time Before: 0.01789 seconds
Time After: 0.01912 seconds
Memory Before: 2,147.313 KB
Memory After: 2,147.172 KB
Time Before: 0.01384 seconds
Time After: 0.01932 seconds
Time Taken: 0.00547 seconds
Memory Before: 2,127.430 KB
Memory After: 2,260.523 KB
Memory Used: 133.094 KB
Time Before: 0.02477 seconds
Time After: 0.02519 seconds
Memory Before: 2,814.047 KB
Memory After: 2,814.563 KB
Time Before: 0.02900 seconds
Time After: 0.03022 seconds
Memory Before: 2,902.336 KB
Memory After: 2,902.930 KB
Time Before: 0.03410 seconds
Time After: 0.03425 seconds
Memory Before: 3,539.156 KB
Memory After: 3,539.586 KB
Time Before: 0.03631 seconds
Time After: 0.03784 seconds
Time Taken: 0.00153 seconds
Memory Before: 3,820.688 KB
Memory After: 3,822.375 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=114254' WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.05088 seconds
Time After: 0.05120 seconds
Memory Before: 4,298.742 KB
Memory After: 4,298.984 KB
