Time Before: 0.00157 seconds
Time After: 0.00239 seconds
Time Taken: 0.00082 seconds
Time Before: 0.00248 seconds
Time After: 0.00414 seconds
Time Taken: 0.00166 seconds
Time Before: 0.00501 seconds
Time After: 0.00518 seconds
Time Before: 0.00613 seconds
Time After: 0.00942 seconds
Time Taken: 0.00329 seconds
Time Before: 0.00525 seconds
Time After: 0.01436 seconds
Time Taken: 0.00911 seconds
Time Before: 0.01704 seconds
Time After: 0.01746 seconds
Time Before: 0.02001 seconds
Time After: 0.02120 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01609 seconds
Time After: 0.02138 seconds
Time Taken: 0.00530 seconds
Memory After: 2,261.820 KB
Time Before: 0.02773 seconds
Time After: 0.02790 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.03004 seconds
Time After: 0.03125 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.03492 seconds
Time After: 0.03506 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03789 seconds
Time After: 0.04061 seconds
Time Taken: 0.00272 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789029519, location = '/forums/private.php?do=newpm&explain=1&u=114280' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05687 seconds
Time After: 0.05720 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
