Time Before: 0.00577 seconds
Time After: 0.00806 seconds
Time Taken: 0.00229 seconds
Time Before: 0.00815 seconds
Time After: 0.00873 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00906 seconds
Time After: 0.00922 seconds
Time Before: 0.01001 seconds
Time After: 0.01239 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00928 seconds
Time After: 0.01717 seconds
Time Taken: 0.00789 seconds
Time Before: 0.02135 seconds
Time After: 0.02180 seconds
Time Before: 0.02329 seconds
Time After: 0.02448 seconds
Time Before: 0.02061 seconds
Time After: 0.02469 seconds
Time Taken: 0.00408 seconds
Time Before: 0.03641 seconds
Time After: 0.03658 seconds
Time Before: 0.04337 seconds
Time After: 0.04467 seconds
End call of global.php: 0.047011137008667
Time Before: 0.04955 seconds
Time After: 0.04974 seconds
Time Before: 0.05263 seconds
Time After: 0.05411 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=114289', badlocation = 1
Time Before: 0.07354 seconds
Time After: 0.07399 seconds
Page generated in 0.072247982025146 seconds with 9 queries, spending 0.0083515644073486 doing MySQL queries and 0.063896417617798 doing PHP things.
