Time Before: 0.00140 seconds
Time After: 0.00195 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00202 seconds
Time After: 0.00256 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00284 seconds
Time After: 0.00299 seconds
Time Before: 0.00387 seconds
Time After: 0.00702 seconds
Time Taken: 0.00314 seconds
Time Before: 0.00307 seconds
Time After: 0.01182 seconds
Time Taken: 0.00875 seconds
Time Before: 0.01411 seconds
Time After: 0.01449 seconds
Time Before: 0.01592 seconds
Time After: 0.01722 seconds
Time Before: 0.01345 seconds
Time After: 0.01741 seconds
Time Taken: 0.00396 seconds
Time Before: 0.02436 seconds
Time After: 0.02458 seconds
Time Before: 0.02652 seconds
Time After: 0.02781 seconds
Time Before: 0.03094 seconds
Time After: 0.03116 seconds
Time Before: 0.03327 seconds
Time After: 0.03476 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=114423' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04905 seconds
Time After: 0.04930 seconds
