Time Before: 0.01414 seconds
Time After: 0.01729 seconds
Time Taken: 0.00315 seconds
Time Before: 0.01740 seconds
Time After: 0.01784 seconds
Time Before: 0.01821 seconds
Time After: 0.01833 seconds
Time Before: 0.01922 seconds
Time After: 0.02514 seconds
Time Taken: 0.00592 seconds
Time Before: 0.01841 seconds
Time After: 0.02916 seconds
Time Taken: 0.01074 seconds
Time Before: 0.03608 seconds
Time After: 0.03650 seconds
Time Before: 0.04008 seconds
Time After: 0.04140 seconds
Time Taken: 0.00132 seconds
Time Before: 0.03533 seconds
Time After: 0.04167 seconds
Time Taken: 0.00634 seconds
Time Before: 0.06803 seconds
Time After: 0.06815 seconds
Time Before: 0.07757 seconds
Time After: 0.07884 seconds
Time Before: 0.08608 seconds
Time After: 0.08622 seconds
Time Before: 0.08862 seconds
Time After: 0.09005 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=114438', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.10721 seconds
Time After: 0.10747 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
