Time Before: 0.00154 seconds
Time After: 0.00217 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00224 seconds
Time After: 0.00267 seconds
Time Before: 0.00291 seconds
Time After: 0.00311 seconds
Time Before: 0.00380 seconds
Time After: 0.00642 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00316 seconds
Time After: 0.01127 seconds
Time Taken: 0.00812 seconds
Time Before: 0.01322 seconds
Time After: 0.01344 seconds
Time Before: 0.01590 seconds
Time After: 0.01713 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01263 seconds
Time After: 0.01730 seconds
Time Taken: 0.00468 seconds
Memory After: 2,261.820 KB
Time Before: 0.02216 seconds
Time After: 0.02233 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02477 seconds
Time After: 0.02601 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.028199911117554
Time Before: 0.02933 seconds
Time After: 0.02949 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03153 seconds
Time After: 0.03312 seconds
Time Taken: 0.00159 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789068797, location = '/forums/private.php?do=newpm&explain=1&u=114472', badlocation = 1
Time Before: 0.04636 seconds
Time After: 0.04691 seconds
Time Taken: 0.00054 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.045433044433594 seconds with 9 queries, spending 0.0084214210510254 doing MySQL queries and 0.037011623382568 doing PHP things.
