Time Before: 0.01306 seconds
Time After: 0.01651 seconds
Time Taken: 0.00345 seconds
Time Before: 0.01660 seconds
Time After: 0.01704 seconds
Time Before: 0.01726 seconds
Time After: 0.01740 seconds
Time Before: 0.01827 seconds
Time After: 0.02077 seconds
Time Taken: 0.00250 seconds
Time Before: 0.01747 seconds
Time After: 0.02525 seconds
Time Taken: 0.00777 seconds
Time Before: 0.03178 seconds
Time After: 0.03222 seconds
Time Before: 0.03371 seconds
Time After: 0.03497 seconds
Time Before: 0.03102 seconds
Time After: 0.03527 seconds
Time Taken: 0.00425 seconds
Time Before: 0.06260 seconds
Time After: 0.06284 seconds
Time Before: 0.08300 seconds
Time After: 0.08442 seconds
Time Before: 0.09407 seconds
Time After: 0.09423 seconds
Time Before: 0.09683 seconds
Time After: 0.09828 seconds
UPDATE session SET lastactivity = 1776558485, location = '/forums/private.php?do=newpm&explain=1&u=114476' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.11568 seconds
Time After: 0.11603 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
