Time Before: 0.00218 seconds
Time After: 0.00306 seconds
Time Taken: 0.00088 seconds
Time Before: 0.00313 seconds
Time After: 0.00442 seconds
Time Before: 0.00494 seconds
Time After: 0.00506 seconds
Time Before: 0.00580 seconds
Time After: 0.00851 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00511 seconds
Time After: 0.01192 seconds
Time Taken: 0.00681 seconds
Time Before: 0.01359 seconds
Time After: 0.01398 seconds
Time Before: 0.01702 seconds
Time After: 0.01828 seconds
Time Before: 0.01301 seconds
Time After: 0.01845 seconds
Time Taken: 0.00544 seconds
Time Before: 0.02385 seconds
Time After: 0.02398 seconds
Time Before: 0.02601 seconds
Time After: 0.02727 seconds
End call of global.php: 0.028942108154297
Time Before: 0.03074 seconds
Time After: 0.03113 seconds
Time Before: 0.03416 seconds
Time After: 0.03561 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=114535'
Time Before: 0.05292 seconds
Time After: 0.05317 seconds
Page generated in 0.052020072937012 seconds with 9 queries, spending 0.0092411041259766 doing MySQL queries and 0.042778968811035 doing PHP things.
