Time Before: 0.00131 seconds
Time After: 0.00178 seconds
Time Before: 0.00185 seconds
Time After: 0.00234 seconds
Time Before: 0.00257 seconds
Time After: 0.00270 seconds
Time Before: 0.00335 seconds
Time After: 0.00589 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00275 seconds
Time After: 0.01055 seconds
Time Taken: 0.00780 seconds
Time Before: 0.01249 seconds
Time After: 0.01301 seconds
Time Before: 0.01462 seconds
Time After: 0.01608 seconds
Time Before: 0.01177 seconds
Time After: 0.01626 seconds
Time Taken: 0.00449 seconds
Time Before: 0.02134 seconds
Time After: 0.02151 seconds
Time Before: 0.02350 seconds
Time After: 0.02539 seconds
Time Taken: 0.00190 seconds
End call of global.php: 0.027922868728638
Time Before: 0.02923 seconds
Time After: 0.02947 seconds
Time Before: 0.03186 seconds
Time After: 0.03333 seconds
SET lastactivity = 1788893381, location = '/forums/private.php?do=newpm&explain=1&u=114545'
Time Before: 0.04578 seconds
Time After: 0.04615 seconds
Page generated in 0.044884920120239 seconds with 9 queries, spending 0.0092709064483643 doing MySQL queries and 0.035614013671875 doing PHP things.
