Time Before: 0.02144 seconds
Time After: 0.02887 seconds
Time Taken: 0.00743 seconds
Time Before: 0.02896 seconds
Time After: 0.02941 seconds
Time Before: 0.02964 seconds
Time After: 0.02981 seconds
Time Before: 0.03050 seconds
Time After: 0.03330 seconds
Time Taken: 0.00281 seconds
Time Before: 0.02989 seconds
Time After: 0.03858 seconds
Time Taken: 0.00869 seconds
Time Before: 0.04773 seconds
Time After: 0.04805 seconds
Time Before: 0.04970 seconds
Time After: 0.05084 seconds
Time Taken: 0.00115 seconds
Time Before: 0.04714 seconds
Time After: 0.05108 seconds
Time Taken: 0.00394 seconds
Time Before: 0.09412 seconds
Time After: 0.09429 seconds
Time Before: 0.22644 seconds
Time After: 0.22808 seconds
Time Taken: 0.00165 seconds
Time Before: 0.23779 seconds
Time After: 0.23793 seconds
Time Before: 0.24077 seconds
Time After: 0.24226 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=11456', badlocation = 1 WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.26460 seconds
Time After: 0.26478 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
