Time Before: 0.00253 seconds
Time After: 0.00298 seconds
Time Before: 0.00305 seconds
Time After: 0.00352 seconds
Time Before: 0.00379 seconds
Time After: 0.00393 seconds
Time Before: 0.00487 seconds
Time After: 0.00759 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00401 seconds
Time After: 0.01310 seconds
Time Taken: 0.00909 seconds
Time Before: 0.01588 seconds
Time After: 0.01633 seconds
Time Before: 0.01977 seconds
Time After: 0.02110 seconds
Time Taken: 0.00133 seconds
Time Before: 0.01506 seconds
Time After: 0.02138 seconds
Time Taken: 0.00631 seconds
Time Before: 0.02881 seconds
Time After: 0.02895 seconds
Time Before: 0.03324 seconds
Time After: 0.03450 seconds
Time Before: 0.03895 seconds
Time After: 0.03915 seconds
Time Before: 0.04202 seconds
Time After: 0.04354 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1785362278, location = '/forums/private.php?do=newpm&explain=1&u=114602' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.06383 seconds
Time After: 0.06421 seconds
