Time Before: 0.00507 seconds
Time After: 0.00648 seconds
Time Before: 0.00658 seconds
Time After: 0.00705 seconds
Time Before: 0.00846 seconds
Time After: 0.00862 seconds
Time Before: 0.00951 seconds
Time After: 0.01202 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00871 seconds
Time After: 0.01639 seconds
Time Taken: 0.00768 seconds
Time Before: 0.01961 seconds
Time After: 0.01987 seconds
Time Before: 0.02239 seconds
Time After: 0.02412 seconds
Time Taken: 0.00174 seconds
Time Before: 0.01891 seconds
Time After: 0.02439 seconds
Time Taken: 0.00548 seconds
Time Before: 0.03917 seconds
Time After: 0.03930 seconds
Time Before: 0.04471 seconds
Time After: 0.04597 seconds
End call of global.php: 0.048332929611206
Time Before: 0.05119 seconds
Time After: 0.05135 seconds
Time Before: 0.05371 seconds
Time After: 0.05512 seconds
SET lastactivity = 1788872172, location = '/forums/private.php?do=newpm&explain=1&u=114606'
Time Before: 0.07251 seconds
Time After: 0.07314 seconds
Time Taken: 0.00063 seconds
Page generated in 0.071434020996094 seconds with 9 queries, spending 0.0087313652038574 doing MySQL queries and 0.062702655792236 doing PHP things.
