Time Before: 0.00287 seconds
Time After: 0.00412 seconds
Time Before: 0.00421 seconds
Time After: 0.00460 seconds
Time Before: 0.00485 seconds
Time After: 0.00498 seconds
Time Before: 0.00588 seconds
Time After: 0.00868 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00503 seconds
Time After: 0.01330 seconds
Time Taken: 0.00827 seconds
Time Before: 0.01697 seconds
Time After: 0.01763 seconds
Time Taken: 0.00066 seconds
Time Before: 0.02077 seconds
Time After: 0.02196 seconds
Time Before: 0.01615 seconds
Time After: 0.02222 seconds
Time Taken: 0.00607 seconds
Time Before: 0.03274 seconds
Time After: 0.03289 seconds
Time Before: 0.03776 seconds
Time After: 0.03900 seconds
Time Before: 0.04358 seconds
Time After: 0.04374 seconds
Time Before: 0.04679 seconds
Time After: 0.04823 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=114607', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.06211 seconds
Time After: 0.06264 seconds
Time Taken: 0.00053 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
