Time Before: 0.00145 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00246 seconds
Time Before: 0.00273 seconds
Time After: 0.00286 seconds
Time Before: 0.00382 seconds
Time After: 0.00651 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00295 seconds
Time After: 0.01219 seconds
Time Taken: 0.00924 seconds
Time Before: 0.01433 seconds
Time After: 0.01479 seconds
Time Before: 0.01807 seconds
Time After: 0.01928 seconds
Time Before: 0.01359 seconds
Time After: 0.01956 seconds
Time Taken: 0.00597 seconds
Time Before: 0.02538 seconds
Time After: 0.02552 seconds
Time Before: 0.02792 seconds
Time After: 0.02917 seconds
Time Before: 0.03342 seconds
Time After: 0.03358 seconds
Time Before: 0.03637 seconds
Time After: 0.03780 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=114609' WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.05518 seconds
Time After: 0.05558 seconds
