Time Before: 0.02097 seconds
Time After: 0.02616 seconds
Time Taken: 0.00520 seconds
Time Before: 0.02628 seconds
Time After: 0.02675 seconds
Time Before: 0.02699 seconds
Time After: 0.02713 seconds
Time Before: 0.02807 seconds
Time After: 0.03064 seconds
Time Taken: 0.00256 seconds
Time Before: 0.02718 seconds
Time After: 0.03476 seconds
Time Taken: 0.00758 seconds
Time Before: 0.04009 seconds
Time After: 0.04028 seconds
Time Before: 0.04364 seconds
Time After: 0.04486 seconds
Time Before: 0.03931 seconds
Time After: 0.04508 seconds
Time Taken: 0.00578 seconds
Time Before: 0.07054 seconds
Time After: 0.07068 seconds
Time Before: 0.16389 seconds
Time After: 0.16512 seconds
Time Before: 0.17098 seconds
Time After: 0.17116 seconds
Time Before: 0.17483 seconds
Time After: 0.17631 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=114624', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.19526 seconds
Time After: 0.19574 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
