Time Before: 0.01828 seconds
Time After: 0.02525 seconds
Time Taken: 0.00697 seconds
Time Before: 0.02536 seconds
Time After: 0.02578 seconds
Time Before: 0.02616 seconds
Time After: 0.02631 seconds
Time Before: 0.02711 seconds
Time After: 0.02931 seconds
Time Taken: 0.00221 seconds
Time Before: 0.02639 seconds
Time After: 0.03353 seconds
Time Taken: 0.00715 seconds
Time Before: 0.04044 seconds
Time After: 0.04084 seconds
Time Before: 0.04329 seconds
Time After: 0.04446 seconds
Time Taken: 0.00117 seconds
Time Before: 0.03977 seconds
Time After: 0.04466 seconds
Time Taken: 0.00489 seconds
Time Before: 0.07693 seconds
Time After: 0.07708 seconds
Time Before: 0.09200 seconds
Time After: 0.09330 seconds
End call of global.php: 0.095863103866577
Time Before: 0.10205 seconds
Time After: 0.10224 seconds
Time Before: 0.10460 seconds
Time After: 0.10612 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=114626'
Time Before: 0.12284 seconds
Time After: 0.12311 seconds
Page generated in 0.12182092666626 seconds with 9 queries, spending 0.0077648162841797 doing MySQL queries and 0.11405611038208 doing PHP things.
