Time Before: 0.00196 seconds
Time After: 0.00257 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00267 seconds
Time After: 0.00307 seconds
Time Before: 0.00334 seconds
Time After: 0.00351 seconds
Time Before: 0.00422 seconds
Time After: 0.00671 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00359 seconds
Time After: 0.01210 seconds
Time Taken: 0.00851 seconds
Time Before: 0.01397 seconds
Time After: 0.01444 seconds
Time Before: 0.01743 seconds
Time After: 0.01866 seconds
Time Before: 0.01340 seconds
Time After: 0.01883 seconds
Time Taken: 0.00543 seconds
Time Before: 0.02389 seconds
Time After: 0.02399 seconds
Time Taken: 0.00010 seconds
Time Before: 0.02588 seconds
Time After: 0.02713 seconds
Time Before: 0.03013 seconds
Time After: 0.03031 seconds
Time Before: 0.03230 seconds
Time After: 0.03372 seconds
UPDATE session SET lastactivity = 1784741618, location = '/forums/private.php?do=newpm&explain=1&u=114648' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.04782 seconds
Time After: 0.04813 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
