Time Before: 0.02287 seconds
Time After: 0.03183 seconds
Time Taken: 0.00896 seconds
Time Before: 0.03194 seconds
Time After: 0.03233 seconds
Time Before: 0.03265 seconds
Time After: 0.03277 seconds
Time Before: 0.03358 seconds
Time After: 0.03605 seconds
Time Taken: 0.00247 seconds
Time Before: 0.03283 seconds
Time After: 0.04101 seconds
Time Taken: 0.00818 seconds
Time Before: 0.05251 seconds
Time After: 0.05298 seconds
Time Before: 0.05570 seconds
Time After: 0.05690 seconds
Time Before: 0.05164 seconds
Time After: 0.05716 seconds
Time Taken: 0.00552 seconds
Memory After: 2,262.391 KB
Time Before: 0.11551 seconds
Time After: 0.11563 seconds
Memory Before: 2,815.914 KB
Memory After: 2,816.430 KB
Time Before: 0.22524 seconds
Time After: 0.22648 seconds
Memory Before: 2,904.109 KB
Memory After: 2,904.703 KB
End call of global.php: 0.22860717773438
Time Before: 0.24047 seconds
Time After: 0.24062 seconds
Memory Before: 3,540.906 KB
Memory After: 3,541.336 KB
Time Before: 0.24373 seconds
Time After: 0.24522 seconds
Memory Before: 3,822.484 KB
Memory After: 3,824.172 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=114665', badlocation = 1
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.26565 seconds
Time After: 0.26593 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.26415395736694 seconds with 9 queries, spending 0.0079131126403809 doing MySQL queries and 0.25624084472656 doing PHP things.
