Time Before: 0.00144 seconds
Time After: 0.00192 seconds
Time Before: 0.00198 seconds
Time After: 0.00234 seconds
Time Before: 0.00252 seconds
Time After: 0.00264 seconds
Time Before: 0.00335 seconds
Time After: 0.00593 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00268 seconds
Time After: 0.01140 seconds
Time Taken: 0.00872 seconds
Time Before: 0.01408 seconds
Time After: 0.01430 seconds
Time Before: 0.01779 seconds
Time After: 0.01900 seconds
Time Before: 0.01325 seconds
Time After: 0.01930 seconds
Time Taken: 0.00604 seconds
Time Before: 0.02717 seconds
Time After: 0.02731 seconds
Time Before: 0.02962 seconds
Time After: 0.03085 seconds
End call of global.php: 0.033571004867554
Time Before: 0.03512 seconds
Time After: 0.03527 seconds
Time Before: 0.03841 seconds
Time After: 0.03986 seconds
SET lastactivity = 1783000913, location = '/forums/private.php?do=newpm&explain=1&u=114666'
Time Before: 0.05445 seconds
Time After: 0.05488 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
Page generated in 0.053500890731812 seconds with 9 queries, spending 0.0078713893890381 doing MySQL queries and 0.045629501342773 doing PHP things.
