Time Before: 0.01931 seconds
Time After: 0.02185 seconds
Time Taken: 0.00254 seconds
Time Before: 0.02195 seconds
Time After: 0.02240 seconds
Time Before: 0.02262 seconds
Time After: 0.02276 seconds
Time Before: 0.02366 seconds
Time After: 0.02587 seconds
Time Taken: 0.00221 seconds
Time Before: 0.02283 seconds
Time After: 0.03039 seconds
Time Taken: 0.00757 seconds
Time Before: 0.03515 seconds
Time After: 0.03563 seconds
Time Before: 0.03919 seconds
Time After: 0.04039 seconds
Time Before: 0.03448 seconds
Time After: 0.04063 seconds
Time Taken: 0.00616 seconds
Time Before: 0.07068 seconds
Time After: 0.07082 seconds
Time Before: 0.08619 seconds
Time After: 0.08773 seconds
Time Taken: 0.00154 seconds
End call of global.php: 0.090582847595215
Time Before: 0.09639 seconds
Time After: 0.09660 seconds
Time Before: 0.09921 seconds
Time After: 0.10063 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=11467'
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.11956 seconds
Time After: 0.11988 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.11844301223755 seconds with 9 queries, spending 0.0081357955932617 doing MySQL queries and 0.11030721664429 doing PHP things.
