Time Before: 0.00138 seconds
Time After: 0.00229 seconds
Time Taken: 0.00091 seconds
Time Before: 0.00236 seconds
Time After: 0.00401 seconds
Time Taken: 0.00165 seconds
Time Before: 0.00429 seconds
Time After: 0.00445 seconds
Time Before: 0.00509 seconds
Time After: 0.00806 seconds
Time Taken: 0.00297 seconds
Time Before: 0.00450 seconds
Time After: 0.01149 seconds
Time Taken: 0.00699 seconds
Time Before: 0.01339 seconds
Time After: 0.01380 seconds
Time Before: 0.01515 seconds
Time After: 0.01639 seconds
Time Before: 0.01284 seconds
Time After: 0.01657 seconds
Time Taken: 0.00373 seconds
Time Before: 0.02180 seconds
Time After: 0.02200 seconds
Time Before: 0.02415 seconds
Time After: 0.02540 seconds
Time Before: 0.02844 seconds
Time After: 0.02876 seconds
Time Before: 0.03089 seconds
Time After: 0.03248 seconds
Time Taken: 0.00158 seconds
UPDATE session SET lastactivity = 1789115254, location = '/forums/private.php?do=newpm&explain=1&u=114680' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04485 seconds
Time After: 0.04525 seconds
