Time Before: 0.00173 seconds
Time After: 0.00256 seconds
Time Taken: 0.00083 seconds
Time Before: 0.00264 seconds
Time After: 0.00324 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00345 seconds
Time After: 0.00358 seconds
Time Before: 0.00429 seconds
Time After: 0.00661 seconds
Time Taken: 0.00231 seconds
Time Before: 0.00363 seconds
Time After: 0.01002 seconds
Time Taken: 0.00639 seconds
Time Before: 0.01257 seconds
Time After: 0.01308 seconds
Time Before: 0.01546 seconds
Time After: 0.01673 seconds
Time Before: 0.01175 seconds
Time After: 0.01692 seconds
Time Taken: 0.00517 seconds
Time Before: 0.02214 seconds
Time After: 0.02226 seconds
Time Before: 0.02434 seconds
Time After: 0.02581 seconds
Time Before: 0.02880 seconds
Time After: 0.02897 seconds
Time Before: 0.03111 seconds
Time After: 0.03257 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=114682' WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.04515 seconds
Time After: 0.04550 seconds
