Time Before: 0.02476 seconds
Time After: 0.02979 seconds
Time Taken: 0.00504 seconds
Time Before: 0.02987 seconds
Time After: 0.03040 seconds
Time Taken: 0.00054 seconds
Time Before: 0.03071 seconds
Time After: 0.03085 seconds
Time Before: 0.03164 seconds
Time After: 0.03418 seconds
Time Taken: 0.00254 seconds
Time Before: 0.03092 seconds
Time After: 0.03803 seconds
Time Taken: 0.00711 seconds
Time Before: 0.04531 seconds
Time After: 0.04571 seconds
Time Before: 0.04711 seconds
Time After: 0.04840 seconds
Time Before: 0.04465 seconds
Time After: 0.04864 seconds
Time Taken: 0.00399 seconds
Time Before: 0.08794 seconds
Time After: 0.08809 seconds
Time Before: 0.10360 seconds
Time After: 0.10481 seconds
End call of global.php: 0.10695600509644
Time Before: 0.11376 seconds
Time After: 0.11392 seconds
Time Before: 0.11624 seconds
Time After: 0.11769 seconds
SET lastactivity = 1784790071, location = '/forums/private.php?do=newpm&explain=1&u=114710'
Time Before: 0.13877 seconds
Time After: 0.13906 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.13738894462585 seconds with 9 queries, spending 0.0081617832183838 doing MySQL queries and 0.12922716140747 doing PHP things.
