Time Before: 0.01107 seconds
Time After: 0.01433 seconds
Time Taken: 0.00325 seconds
Time Before: 0.01443 seconds
Time After: 0.01524 seconds
Time Taken: 0.00081 seconds
Time Before: 0.01553 seconds
Time After: 0.01567 seconds
Time Before: 0.01660 seconds
Time After: 0.01875 seconds
Time Taken: 0.00215 seconds
Time Before: 0.01575 seconds
Time After: 0.02319 seconds
Time Taken: 0.00745 seconds
Memory After: 1,642.430 KB
Memory Used: 1,081.023 KB
Time Before: 0.02888 seconds
Time After: 0.02926 seconds
Memory Before: 2,137.359 KB
Memory After: 2,137.977 KB
Time Before: 0.03199 seconds
Time After: 0.03321 seconds
Memory Before: 2,149.422 KB
Memory After: 2,149.281 KB
Time Before: 0.02815 seconds
Time After: 0.03348 seconds
Time Taken: 0.00533 seconds
Memory Before: 2,129.539 KB
Memory After: 2,262.344 KB
Time Before: 0.05305 seconds
Time After: 0.05321 seconds
Memory Before: 2,815.859 KB
Memory After: 2,816.375 KB
Time Before: 0.06184 seconds
Time After: 0.06315 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,904.055 KB
Memory After: 2,904.648 KB
End call of global.php: 0.065184116363525
Time Before: 0.06943 seconds
Time After: 0.06962 seconds
Memory Before: 3,540.836 KB
Memory After: 3,541.266 KB
Time Before: 0.07255 seconds
Time After: 0.07414 seconds
Time Taken: 0.00160 seconds
Memory Before: 3,822.414 KB
Memory After: 3,824.102 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=114739'
Time Before: 0.09125 seconds
Time After: 0.09164 seconds
Memory Before: 4,287.805 KB
Memory After: 4,288.047 KB
Page generated in 0.090110063552856 seconds with 9 queries, spending 0.0083463191986084 doing MySQL queries and 0.081763744354248 doing PHP things.
