Time Before: 0.00128 seconds
Time After: 0.00186 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00193 seconds
Time After: 0.00251 seconds
Time Before: 0.00280 seconds
Time After: 0.00298 seconds
Time Before: 0.00363 seconds
Time After: 0.00637 seconds
Time Taken: 0.00273 seconds
Time Before: 0.00303 seconds
Time After: 0.00978 seconds
Time Taken: 0.00675 seconds
Time Before: 0.01160 seconds
Time After: 0.01195 seconds
Time Before: 0.01436 seconds
Time After: 0.01570 seconds
Time Taken: 0.00134 seconds
Time Before: 0.01104 seconds
Time After: 0.01587 seconds
Time Taken: 0.00483 seconds
Time Before: 0.02071 seconds
Time After: 0.02088 seconds
Time Before: 0.02295 seconds
Time After: 0.02416 seconds
Time Before: 0.02778 seconds
Time After: 0.02794 seconds
Time Before: 0.02994 seconds
Time After: 0.03135 seconds
UPDATE session SET lastactivity = 1789118385, location = '/forums/private.php?do=newpm&explain=1&u=114754' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04420 seconds
Time After: 0.04449 seconds
