Time Before: 0.00147 seconds
Time After: 0.00197 seconds
Time Before: 0.00204 seconds
Time After: 0.00254 seconds
Time Before: 0.00280 seconds
Time After: 0.00299 seconds
Time Before: 0.00370 seconds
Time After: 0.00602 seconds
Time Taken: 0.00232 seconds
Time Before: 0.00304 seconds
Time After: 0.01040 seconds
Time Taken: 0.00736 seconds
Time Before: 0.01243 seconds
Time After: 0.01284 seconds
Time Before: 0.01558 seconds
Time After: 0.01682 seconds
Time Before: 0.01181 seconds
Time After: 0.01707 seconds
Time Taken: 0.00527 seconds
Time Before: 0.02273 seconds
Time After: 0.02287 seconds
Time Before: 0.02523 seconds
Time After: 0.02651 seconds
Time Before: 0.03063 seconds
Time After: 0.03082 seconds
Time Before: 0.03371 seconds
Time After: 0.03515 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=114813', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.05071 seconds
Time After: 0.05409 seconds
Time Taken: 0.00338 seconds
