Time Before: 0.02820 seconds
Time After: 0.03569 seconds
Time Taken: 0.00749 seconds
Memory Before: 532.289 KB
Memory After: 557.406 KB
Time Before: 0.03580 seconds
Time After: 0.03848 seconds
Time Taken: 0.00268 seconds
Memory Before: 557.344 KB
Memory After: 558.352 KB
Time Before: 0.03932 seconds
Time After: 0.03960 seconds
Memory Before: 558.906 KB
Memory After: 559.430 KB
Time Before: 0.04064 seconds
Time After: 0.04290 seconds
Time Taken: 0.00226 seconds
Memory Before: 562.031 KB
Memory After: 562.953 KB
Time Before: 0.03967 seconds
Time After: 0.04679 seconds
Time Taken: 0.00712 seconds
Memory Before: 558.680 KB
Memory After: 1,639.734 KB
Memory Used: 1,081.055 KB
Time Before: 0.05697 seconds
Time After: 0.05778 seconds
Time Taken: 0.00081 seconds
Memory Before: 2,134.656 KB
Memory After: 2,135.273 KB
Time Before: 0.06037 seconds
Time After: 0.06210 seconds
Time Taken: 0.00172 seconds
Memory Before: 2,146.836 KB
Memory After: 2,146.695 KB
Time Before: 0.05583 seconds
Time After: 0.06237 seconds
Time Taken: 0.00654 seconds
Memory Before: 2,126.836 KB
Memory After: 2,260.047 KB
Memory Used: 133.211 KB
Time Before: 0.09759 seconds
Time After: 0.09775 seconds
Memory Before: 2,813.594 KB
Memory After: 2,814.109 KB
Time Before: 0.11643 seconds
Time After: 0.11776 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,901.883 KB
Memory After: 2,902.477 KB
Time Before: 0.13214 seconds
Time After: 0.13230 seconds
Memory Before: 3,538.656 KB
Memory After: 3,539.086 KB
Time Before: 0.13485 seconds
Time After: 0.13630 seconds
Memory Before: 3,820.188 KB
Memory After: 3,821.875 KB
UPDATE session SET lastactivity = 1789015021, location = '/forums/private.php?do=newpm&explain=1&u=114841', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.15604 seconds
Time After: 0.15632 seconds
Memory Before: 4,298.773 KB
Memory After: 4,298.984 KB
