Time Before: 0.01037 seconds
Time After: 0.01265 seconds
Time Taken: 0.00229 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.01275 seconds
Time After: 0.01333 seconds
Time Taken: 0.00058 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.01359 seconds
Time After: 0.01372 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.01460 seconds
Time After: 0.01730 seconds
Time Taken: 0.00270 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.01380 seconds
Time After: 0.02204 seconds
Time Taken: 0.00824 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.02654 seconds
Time After: 0.02677 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.02820 seconds
Time After: 0.02941 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.02575 seconds
Time After: 0.02968 seconds
Time Taken: 0.00393 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.04960 seconds
Time After: 0.04975 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.26218 seconds
Time After: 0.26351 seconds
Time Taken: 0.00133 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.27929 seconds
Time After: 0.27945 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.28262 seconds
Time After: 0.28406 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1768695123, location = '/forums/private.php?do=newpm&explain=1&u=114851', badlocation = 1 WHERE sessionhash = '86fb755ccb69fa1491ac644ca6ebf439'
Time Before: 0.30513 seconds
Time After: 0.30541 seconds
Memory Before: 5,999.000 KB
Memory After: 5,999.211 KB
