Time Before: 0.00258 seconds
Time After: 0.00314 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00321 seconds
Time After: 0.00356 seconds
Time Before: 0.00376 seconds
Time After: 0.00390 seconds
Time Before: 0.00491 seconds
Time After: 0.00774 seconds
Time Taken: 0.00283 seconds
Time Before: 0.00398 seconds
Time After: 0.01261 seconds
Time Taken: 0.00863 seconds
Time Before: 0.01451 seconds
Time After: 0.01504 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01678 seconds
Time After: 0.01802 seconds
Time Before: 0.01381 seconds
Time After: 0.01825 seconds
Time Taken: 0.00444 seconds
Time Before: 0.02533 seconds
Time After: 0.02550 seconds
Time Before: 0.02786 seconds
Time After: 0.02910 seconds
End call of global.php: 0.031509876251221
Time Before: 0.03323 seconds
Time After: 0.03366 seconds
Time Before: 0.03724 seconds
Time After: 0.03887 seconds
Time Taken: 0.00164 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=114948', badlocation = 1
Time Before: 0.05916 seconds
Time After: 0.06847 seconds
Time Taken: 0.00931 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.058195829391479 seconds with 9 queries, spending 0.017887830734253 doing MySQL queries and 0.040307998657227 doing PHP things.
