Time Before: 0.01225 seconds
Time After: 0.01604 seconds
Time Taken: 0.00379 seconds
Time Before: 0.01612 seconds
Time After: 0.01652 seconds
Time Before: 0.01682 seconds
Time After: 0.01697 seconds
Time Before: 0.01789 seconds
Time After: 0.02005 seconds
Time Taken: 0.00216 seconds
Time Before: 0.01706 seconds
Time After: 0.02433 seconds
Time Taken: 0.00727 seconds
Time Before: 0.03049 seconds
Time After: 0.03090 seconds
Time Before: 0.03344 seconds
Time After: 0.03466 seconds
Time Before: 0.02983 seconds
Time After: 0.03487 seconds
Time Taken: 0.00504 seconds
Time Before: 0.04939 seconds
Time After: 0.04953 seconds
Time Before: 0.06022 seconds
Time After: 0.06144 seconds
End call of global.php: 0.064140796661377
Time Before: 0.07062 seconds
Time After: 0.07085 seconds
Time Before: 0.07385 seconds
Time After: 0.07527 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=11507'
Time Before: 0.09289 seconds
Time After: 0.09313 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.091892957687378 seconds with 9 queries, spending 0.0075769424438477 doing MySQL queries and 0.08431601524353 doing PHP things.
