Time Before: 0.01496 seconds
Time After: 0.01988 seconds
Time Taken: 0.00492 seconds
Time Before: 0.01999 seconds
Time After: 0.02061 seconds
Time Taken: 0.00062 seconds
Time Before: 0.02089 seconds
Time After: 0.02106 seconds
Time Before: 0.02194 seconds
Time After: 0.02514 seconds
Time Taken: 0.00320 seconds
Time Before: 0.02114 seconds
Time After: 0.02907 seconds
Time Taken: 0.00794 seconds
Time Before: 0.03513 seconds
Time After: 0.03561 seconds
Time Before: 0.03834 seconds
Time After: 0.03956 seconds
Time Before: 0.03449 seconds
Time After: 0.03980 seconds
Time Taken: 0.00531 seconds
Time Before: 0.05854 seconds
Time After: 0.05873 seconds
Time Before: 0.07149 seconds
Time After: 0.07274 seconds
End call of global.php: 0.074854850769043
Time Before: 0.08132 seconds
Time After: 0.08149 seconds
Time Before: 0.08421 seconds
Time After: 0.08571 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1780665485, location = '/forums/private.php?do=newpm&explain=1&u=115081', badlocation = 1
Time Before: 0.10407 seconds
Time After: 0.10436 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.10314798355103 seconds with 9 queries, spending 0.0091140270233154 doing MySQL queries and 0.09403395652771 doing PHP things.
