Time Before: 0.00153 seconds
Time After: 0.00213 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00225 seconds
Time After: 0.00275 seconds
Time Before: 0.00300 seconds
Time After: 0.00311 seconds
Time Before: 0.00384 seconds
Time After: 0.00625 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00316 seconds
Time After: 0.00962 seconds
Time Taken: 0.00646 seconds
Time Before: 0.01147 seconds
Time After: 0.01187 seconds
Time Before: 0.01427 seconds
Time After: 0.01545 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01084 seconds
Time After: 0.01561 seconds
Time Taken: 0.00478 seconds
Time Before: 0.02055 seconds
Time After: 0.02076 seconds
Time Before: 0.02268 seconds
Time After: 0.02394 seconds
End call of global.php: 0.025666952133179
Time Before: 0.02694 seconds
Time After: 0.02706 seconds
Time Before: 0.02927 seconds
Time After: 0.03130 seconds
Time Taken: 0.00202 seconds
SET lastactivity = 1776463683, location = '/forums/private.php?do=newpm&explain=1&u=115112', badlocation = 1
Time Before: 0.04368 seconds
Time After: 0.04402 seconds
Page generated in 0.042787075042725 seconds with 9 queries, spending 0.0085606575012207 doing MySQL queries and 0.034226417541504 doing PHP things.
