Time Before: 0.01356 seconds
Time After: 0.01853 seconds
Time Taken: 0.00497 seconds
Time Before: 0.01865 seconds
Time After: 0.01917 seconds
Time Before: 0.01943 seconds
Time After: 0.01962 seconds
Time Before: 0.02050 seconds
Time After: 0.02367 seconds
Time Taken: 0.00317 seconds
Time Before: 0.01969 seconds
Time After: 0.02759 seconds
Time Taken: 0.00789 seconds
Time Before: 0.03459 seconds
Time After: 0.03511 seconds
Time Before: 0.03768 seconds
Time After: 0.03900 seconds
Time Taken: 0.00133 seconds
Time Before: 0.03382 seconds
Time After: 0.03920 seconds
Time Taken: 0.00538 seconds
Time Before: 0.06160 seconds
Time After: 0.06172 seconds
Time Before: 0.07278 seconds
Time After: 0.07402 seconds
Time Before: 0.08206 seconds
Time After: 0.08227 seconds
Time Before: 0.08519 seconds
Time After: 0.08668 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=115153', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.10686 seconds
Time After: 0.10716 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
