Time Before: 0.00146 seconds
Time After: 0.00199 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00206 seconds
Time After: 0.00250 seconds
Time Before: 0.00271 seconds
Time After: 0.00282 seconds
Time Before: 0.00348 seconds
Time After: 0.00638 seconds
Time Taken: 0.00290 seconds
Time Before: 0.00286 seconds
Time After: 0.00970 seconds
Time Taken: 0.00684 seconds
Time Before: 0.01147 seconds
Time After: 0.01183 seconds
Time Before: 0.01312 seconds
Time After: 0.01433 seconds
Time Before: 0.01093 seconds
Time After: 0.01457 seconds
Time Taken: 0.00364 seconds
Time Before: 0.02049 seconds
Time After: 0.02070 seconds
Time Before: 0.02289 seconds
Time After: 0.02415 seconds
End call of global.php: 0.026727914810181
Time Before: 0.02814 seconds
Time After: 0.02834 seconds
Time Before: 0.03108 seconds
Time After: 0.03255 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=115185'
Time Before: 0.04607 seconds
Time After: 0.04636 seconds
Page generated in 0.045199871063232 seconds with 9 queries, spending 0.0084316730499268 doing MySQL queries and 0.036768198013306 doing PHP things.
