Time Before: 0.00482 seconds
Time After: 0.00636 seconds
Time Taken: 0.00154 seconds
Time Before: 0.00644 seconds
Time After: 0.00694 seconds
Time Before: 0.00718 seconds
Time After: 0.00734 seconds
Time Before: 0.00811 seconds
Time After: 0.01047 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00741 seconds
Time After: 0.01537 seconds
Time Taken: 0.00796 seconds
Time Before: 0.01929 seconds
Time After: 0.01960 seconds
Time Before: 0.02234 seconds
Time After: 0.02359 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01845 seconds
Time After: 0.02381 seconds
Time Taken: 0.00536 seconds
Memory After: 2,261.820 KB
Time Before: 0.03684 seconds
Time After: 0.03708 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.04126 seconds
Time After: 0.04251 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.045165061950684
Time Before: 0.04684 seconds
Time After: 0.04699 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.04987 seconds
Time After: 0.05132 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789110193, location = '/forums/private.php?do=newpm&explain=1&u=115210'
Time Before: 0.06925 seconds
Time After: 0.06969 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.068060874938965 seconds with 9 queries, spending 0.0080909729003906 doing MySQL queries and 0.059969902038574 doing PHP things.
