Time Before: 0.00194 seconds
Time After: 0.00248 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00255 seconds
Time After: 0.00310 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00333 seconds
Time After: 0.00347 seconds
Time Before: 0.00416 seconds
Time After: 0.00664 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00352 seconds
Time After: 0.01005 seconds
Time Taken: 0.00653 seconds
Time Before: 0.01206 seconds
Time After: 0.01248 seconds
Time Before: 0.01515 seconds
Time After: 0.01642 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01153 seconds
Time After: 0.01659 seconds
Time Taken: 0.00505 seconds
Memory After: 2,261.703 KB
Time Before: 0.02412 seconds
Time After: 0.02427 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02681 seconds
Time After: 0.02809 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.029772996902466
Time Before: 0.03120 seconds
Time After: 0.03162 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03492 seconds
Time After: 0.03638 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=115219'
Time Before: 0.04996 seconds
Time After: 0.05029 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.049036979675293 seconds with 9 queries, spending 0.0085105895996094 doing MySQL queries and 0.040526390075684 doing PHP things.
