Time Before: 0.03196 seconds
Time After: 0.03834 seconds
Time Taken: 0.00639 seconds
Time Before: 0.03847 seconds
Time After: 0.03889 seconds
Time Before: 0.03921 seconds
Time After: 0.03933 seconds
Time Before: 0.04015 seconds
Time After: 0.04204 seconds
Time Taken: 0.00188 seconds
Time Before: 0.03940 seconds
Time After: 0.04614 seconds
Time Taken: 0.00674 seconds
Time Before: 0.05612 seconds
Time After: 0.05707 seconds
Time Taken: 0.00095 seconds
Time Before: 0.05967 seconds
Time After: 0.06093 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05493 seconds
Time After: 0.06114 seconds
Time Taken: 0.00621 seconds
Memory After: 2,261.703 KB
Time Before: 0.10921 seconds
Time After: 0.10933 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.15429 seconds
Time After: 0.15554 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.16768 seconds
Time After: 0.16786 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.17088 seconds
Time After: 0.17233 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=115275', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.19268 seconds
Time After: 0.19294 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
