Time Before: 0.01018 seconds
Time After: 0.01347 seconds
Time Taken: 0.00330 seconds
Time Before: 0.01360 seconds
Time After: 0.01399 seconds
Time Before: 0.01421 seconds
Time After: 0.01434 seconds
Time Before: 0.01516 seconds
Time After: 0.01772 seconds
Time Taken: 0.00256 seconds
Time Before: 0.01439 seconds
Time After: 0.02197 seconds
Time Taken: 0.00758 seconds
Time Before: 0.02706 seconds
Time After: 0.02742 seconds
Time Before: 0.03021 seconds
Time After: 0.03143 seconds
Time Before: 0.02640 seconds
Time After: 0.03161 seconds
Time Taken: 0.00521 seconds
Time Before: 0.05227 seconds
Time After: 0.05250 seconds
Time Before: 0.06090 seconds
Time After: 0.06282 seconds
Time Taken: 0.00192 seconds
Time Before: 0.06917 seconds
Time After: 0.06939 seconds
Time Before: 0.07173 seconds
Time After: 0.07317 seconds
UPDATE session SET lastactivity = 1776560708, location = '/forums/private.php?do=newpm&explain=1&u=115298', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.08864 seconds
Time After: 0.08900 seconds
