Time Before: 0.01062 seconds
Time After: 0.01289 seconds
Time Taken: 0.00227 seconds
Time Before: 0.01297 seconds
Time After: 0.01346 seconds
Time Before: 0.01374 seconds
Time After: 0.01392 seconds
Time Before: 0.01471 seconds
Time After: 0.01727 seconds
Time Taken: 0.00256 seconds
Time Before: 0.01399 seconds
Time After: 0.02317 seconds
Time Taken: 0.00918 seconds
Time Before: 0.02721 seconds
Time After: 0.02765 seconds
Time Before: 0.02925 seconds
Time After: 0.03058 seconds
Time Taken: 0.00133 seconds
Time Before: 0.02644 seconds
Time After: 0.03080 seconds
Time Taken: 0.00437 seconds
Time Before: 0.05169 seconds
Time After: 0.05186 seconds
Time Before: 0.05937 seconds
Time After: 0.06132 seconds
Time Taken: 0.00195 seconds
Time Before: 0.06757 seconds
Time After: 0.06776 seconds
Time Before: 0.07056 seconds
Time After: 0.07202 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=115306', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.08997 seconds
Time After: 0.09028 seconds
